Headstock tighten
Posted: Fri Oct 17, 2008 5:10 pm
by Mole
Hey guys, is it easy to tighten the headstock?, i got a caution on my M.O.T, and now it's a few months after i can hear a tiny knock when i go over bumps.
Re: Headstock tighten
Posted: Fri Oct 17, 2008 5:42 pm
by NC30V
easy enough, remove top yoke there are two locking nuts tighten the bottom one then the top.. using a c spaner, be carful not to go too tight as steering will be stiff!! then re fit top yoke job done!!!
good look
kev
Posted: Fri Oct 17, 2008 5:43 pm
by Sligeach
as long as you can get the front of the bike off the ground, its easy.
you need the front off the ground so you can see that the bars can move free enough.
you need a 41 socket, i think
Posted: Fri Oct 17, 2008 6:11 pm
by mattUKNC
41mm I think I was told. :D Just bought a socket.
Posted: Mon Oct 20, 2008 4:50 pm
by Mole
Cheers guys, do you know where i can get some new locking washers, one of mine the tab has cracked, and know what size i'd need?
Posted: Mon Oct 20, 2008 10:30 pm
by Sligeach
http://www.davidsilvers.co.uk" onclick="window.open(this.href);return false;
