'89 fzr400r exup manual/advice needed
baldy
Bike owned: FZR400R 3EN2
Post by baldy »
hi all,
been trying to find a link for a manual which works? probably just me being a moron?
could some nice person please tell me:
tire pressures
carb setting (mix screw and jet sizes)
fork oil type and level
best oil (full/semi synth) ('normal' road use)
plug gap
thanks :grin:
Re: '89 fzr400r exup manual/advice needed
Post by Evilchicken0 »
Set it up as the 3TJ service manual, except the forks.
Use 10/40 semi syth oil, remember the bike has to be upright not on the side stand when you check it.
baldy
Post by baldy »
excellent, thanks mate.
erm, where would i find a 3tj manual? :?
The document libary link at the very top of the page ^^^^
baldy
Post by baldy »
awesome! thank you very much sir :grin:
willandrip
Post by willandrip »
Forks are 41mm dia .
523 cc 10 w oil (15 w is recognised replacement to try to compensate for weak standard springs by slowing valve damping)
I have an air gap figure of 90mm; but this does not seem correct.(the manual is Japanese and I cannot discern what this alludes to)
Spring length appears to be 333.5 cm with 328.5 cm wear limit.
(I don't run std springs on either bike.)
The above is for the 3EN2 - it has two round headlights with false air intakes below, they also have the clipons below a flat top yoke
willandrip
That would be a Fzr 400R manufactured in '89 as in the title then Boris !
Plug is CR8E -gap 28-30 thou.
Manufactured yes, but a lot of these bikes have the wrong date on the V5 so better safe than sorry
willandrip
True, Boris-just took it from the title that the owner knew what bike he had,but as you correctly state,many inaccuracies occur with registration.
Baldy;put up some pics of your mount.
