ignition barrel removal/replace with a switch help
Posted: Wed Jun 26, 2013 10:42 am
hey guys, my nc30 barrel doesnt pass current when in the on position. but steering lock works fine. i attempted to remove the lock but wasnt concentrating and stripped on of the torx as they were soo bloody tight, then i figured i could just bolt it back up and just use a hidden switch kind of like a kill switch, i searched it on here and someone said one wire is a 12 volt supply and the other two need power up when in the on position. is this correct. also does any one have a pic of there switch and where they mounted it.
