Carb O rings
britaxcooper
Carb O rings
Please could someone tell me the size of the O rings fitted to the small plastic T piece between carbs 1/2 and 3/4 on a NC23? I'm cleaning one carb at a time and the O-rings have just broken up on removal.
Maelstrom
- Bike owned: MC22, 3TJ1
Re: Carb O rings
The o-rings that I think you are referring to are the float bowl breather Tee piece o-rings, OR-011 on this page:
http://litetek.co/Carb_Kit_Honda_CBR400RR_NC23.html
They are not a standard size.
Assuming the other o-rings and seals in your carbs are the same age, then you should consider replacing all of them. NBR does not last 20 years.
cheers
Blair
cheers
Blair
https://litetek.co
https://litetek.co
- leopard_pagan
Re: Carb O rings
recently bought a full set of carb gaskets from honda for my NC29..
worth doing it right the first time
