NC30 Speedo reading wrong??????
Jmcdonnell82
Hi,
I have just finished building my NC30 and having taken her out for a few test rides I'm not sure the speedo is correct.
I'm following the flow of traffic (approx 70mp)on a dual carriageway and my speedo is reading 90mph. Does anyone know what would cause the difference and how I could fix it??
Cheers.
Cheers.
- Bike owned: VFR400
Re: NC30 Speedo reading wrong??????
What gearing and rear wheel/ryre sizes are you running?
Jmcdonnell82
Standard wheel size but the rear sprocket is a 42 tooth. Would that be the cause? If so how can I fix it?
It drives off the gearbox sprocket and so is fixed to the revs of the bike
fitting a larger rear sprocket will make it read high, but not that high
You sure it is a proper NC30 speedo?
Somebody could have had it apart and took the needle off and then put it on in the wrong place.CMSMJ1 wrote:It drives off the gearbox sprocket and so is fixed to the revs of the bike
After which they are a nightmare to get right.
How many teeth on the gearbox sprocket?
