NC30 runs for a few seconds and then dies
Posted: Mon Jun 10, 2013 9:39 pm
All,
I recently decided to take the carbs off my NC30 and clean and service them. I have now refitted them and am having problems getting the bike to run for more than 8-10 seconds with out cutting out. I assume it must be fuel starvation as it does briefly run, and the fuel hose definitely isn't kinked or blocked, so my thoughts are;
Does the fuel system require bleeding, and if so how?
I have already run the battery flat once trying to start it, is this normal?
What does the vacum hose do? Will sucking on this assist?
I drained the fuel tank prior to refitting it, could this be causing the problem?
Could it be something else?
Many thanks for your help!
Tom
Tom
