NC30 runs for a few seconds and then dies
ireson75
Post by ireson75 »
All,
I recently decided to take the carbs off my NC30 and clean and service them. I have now refitted them and am having problems getting the bike to run for more than 8-10 seconds with out cutting out. I assume it must be fuel starvation as it does briefly run, and the fuel hose definitely isn't kinked or blocked, so my thoughts are;
Does the fuel system require bleeding, and if so how?
I have already run the battery flat once trying to start it, is this normal?
What does the vacum hose do? Will sucking on this assist?
I drained the fuel tank prior to refitting it, could this be causing the problem?
Could it be something else?
Many thanks for your help!
Tom
ireson75
Re: NC30 runs for a few seconds and then dies
Post by ireson75 »
Just to add, it was fine before my tinkering!
hunter
Post by hunter »
Have you put the vacuum pipe back in the right position on the tap.
ireson75
Post by ireson75 »
hunter wrote:Have you put the vacuum pipe back in the right position on the tap.
Yes and checked it isn't kinked or damaged... What exactly does it do? IS this likely to be the cause of my problems?
Which spigot is it on?
I'll bet that hunter has it right
you have 3 jobbies - large one for fuel, 2 small ones.
you put the vacuum on the outside one...not the middle one that points down
Haydn
Post by Haydn »
When I bought my NC30 track bike it had been stood for a while and would only run for a small amount of time before cutting out. The vacuum pipe was on the bottom of the tap not the right hand one, so basically the vacuum was sucking the diagram shut instead of open. Worth checking to be 100% sure.
ireson75
Post by ireson75 »
The vacum hose is definitley on the correct spigot...
Any further ideas???
Bike owned: VFR400
Post by magg »
Tank breather working?
Cammo
Post by Cammo »
Flooded...
ireson75
Post by ireson75 »
Cammo wrote:Flooded...
Would it still run though if it were flooded? I will take a look at the spark plugs anyway...
