R6 shock conversion spring rate
plodder
Post by plodder »
Is the standard spring rate for the R6 what should be used on the 3TJ?
I think it's too hard, with not enough static sag and have had the back wheel jumping up in the air on bumpy roads. Problem is it's already on minimum preload, so the only way to go is to soften the spring.
Does anyone know the spring rate on the standard R6 shock?
Oh and I'm 14 stone if that's of any use.
Re: R6 shock conversion spring rate
Post by Evilchicken0 »
I know Laj Racing was using the shock with no compression preload on but that's a racebike.
Ask a suspension shop for a spring ... and also fit a collar to the top to allow the spring to rotate more freely (they had that in PB magazine)
Motorcycle Solutions
Bike owned: Kawasaki ZX9R E1
Post by Motorcycle Solutions »
Hi if you live close i can come and set your r6 shock up for road use, for i have one on my road bike as well as the race bikes......
If you want this done pm me your number and i will call you.... :D
fzrtim
Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Post by fzrtim »
I set the spring preload on its lowest setting which gave 5mm of static sag. It handles superb on the track but i havent ridden it on the road. Its a lot softer ride than my rsv (but that does rattle your teeth out on bumpy roads)!
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
you could always look at a maxton spring or similar that would be a bit softer and matche to your weight if it wont adgust down enough for you.
plodder
Post by plodder »
Where are you laj and how much are we looking at?
Taggyd
Post by Taggyd »
he's very close to mallory park circuit!
Hi Taggy is correct i am 3miles from mallory park.... Goto to my website and contact us page you will find me number....
It will cost about £25 depending on how long it takes... if need be can meet half way for i have a full mobile work shop...
Chris
http://www.lajracingservices.com" onclick="window.open(this.href);return false;
