Vfr400 NC24 snapped throttle cable
fasttom
- Bike owned: VFR 400 NC24, Kawasaki Z750
After having just stripped bike and including cooling system and completed valve adjustment I wrestle the carbs back in place go to refit throttle cables and one snaps clean off at throttle grip.
Do any of you good people know where best to get replacement cable sets for the NC24 as I have looked at the other one and that is hanging on by a wire? Wemoto sells the pull side of the cable system but not the other! Are NC30 cables the same length?
Re: Vfr400 NC24 snapped throttle cable
you refit the throttle cables before fitting the carbs usually.
NC30 cabels are different, i seem to rememer they are too short
fasttom
Thanks for info, looks like I will have to make a custom set.
or just buy some second hand onesfasttom wrote:Thanks for info, looks like I will have to make a custom set.
