nc31 f2r 1995
Brian
nc31 f2r 1995
can anyone help. have just replaced fork tubes with patent parts from wemoto.the damper tube ring seals were a very tight fit had to use spring to force down tube before doing up the retaining bolt. i filled the tubes with 10w fork oil 499cc as per one of the posts. this has made the front end very stiff you can not push the front end down with the brakes on. it rides ok and brakes very well the legs are going up but only under braking. have i filled tubes up to much or do the new ring seals need to bed in. any help would be appreciated
