nc30 whiny second gear. known problem?
Posted: Wed May 22, 2013 11:02 pm
by Reality
Hey there, dont post often as projects have stalled for quite a while. however i've just managed to bag a couple of engines which need some looking at before one can go in the trackbike chassis i have. The most promising one was described as being a very good runner, but had developed a loud noise when in second gear. the guy i got it from speculated that it could be a problem with a selecter fork or loose shim or spacer. another friend suggested it might be a bearing on the way out. Anyone heard of anything like this before? The second engine was suffering oil pressure loss so might be a bigger job but would be nice to get them both back in shape eventually.
Re: nc30 whiny second gear. known problem?
Posted: Wed May 22, 2013 11:13 pm
by porndoguk
there is a known problem with nc30s second gear when thrashed that it has a habbit of jumping out,
Rick Oliver discovered a cure, get in touch with him hes the best you ask with regards to this
Posted: Fri May 24, 2013 10:15 am
by hunter
Sounds like a bearing to me,But without hearing who knows.
Posted: Mon Jul 08, 2013 7:21 pm
by Ravo
porndoguk wrote:there is a known problem with nc30s second gear when thrashed that it has a habbit of jumping out,
Hi, my nc30 is jumping out of second, how do I get in touch with Rick Oliver cheers.
Posted: Mon Jul 08, 2013 7:44 pm
by porndoguk
Ravo wrote:porndoguk wrote:there is a known problem with nc30s second gear when thrashed that it has a habbit of jumping out,
Call between 5pm - 9pm (GMT)
01603720387
