Wiring in a volt meter to keep an eye on battery
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
So, after sorting out the reg rec wiring (direct to the battery, new crimped and soldered connectors etc) i'd like to keep an eye on the voltage so want to fit a small led volt meter somewhere near the clocks.
I want it to be a switched feed that only gets power when the ignition is on.
Is there anywhere up the front of the bike where i can take a switched feed from? im a bit green when it comes to electrics.
bikemonkey
Re: Wiring in a volt meter to keep an eye on battery
Post by bikemonkey »
Kill switch?
That's part of the switched ignition, and where I'm putting my voltage meter :peace:
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Connect into the black wire from the kill switch so you can monitor even with the KS activated. The black/white is the supply to the Igniter and coils.
I'd also err on the side of caution and put something like a 50mA fuse inline with it too.
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Try this link, got one on my bike and they are good quality and reliable. I got the 5mm one. http://www.ebay.co.uk/itm/a-12v-LED-Bat ... 2308f39a72
dgunthor
Post by dgunthor »
i wired a cigarette lighter socket to the battery, fixed under the screen and have one of these in there for £3 (fully insert it when i want to see the voltage)
http://dx.com/p/led-display-cigarette-l ... -24v-68179
i think it's useful as the electrics are often a source of issues
dgunthor
Post by dgunthor »
(can obviously charge your phone/satnav instead as well then)
carpman
Bike owned: 1990 nc30
Post by carpman »
[quote="dgunthor"]i wired a cigarette lighter socket to the battery, fixed under the screen and have one of these in there for £3 (fully insert it when i want to see the voltage)
i think it's useful as the electrics are often a source of issues[/quote
I wired a watercraft cigarette lighter under the rear seat so I could run satnav and phone charger, never thought of using a volt meter food for thought though.
