nc23 gears problem
bido600
nc23 gears problem
hey guys again
another problem in my nc23
its hard to shift gears
i pull the clutch all the way in when i hit the 1st or the 2nd or any of the other gears its like so heavy ( the pedal its like something stuck on it )
any help ?
any help ?
ZXESAS
Re: nc23 gears problem
Have you changed your oil? Maybe your clutch needs to be replaced! Hope this helps
Emzed
- Bike owned: NC23J/K,750Paso x2,MZ's,BMW C1
Is there enough or "any" oil in it
Em
bido600
1st thanks guys for the reply
i've checked the oil it's between max and min near to the max
and the oild is new only made 100km with it
still the same prob
still the same prob
bazz
hi
is this a sudden issue or has it developed over time? has the bike been dropped or fallen off the stand?
bazz
bazz
- Davez29
- Bike owned: NC29 forever
Is your chain adjusted correctly and not too tight as if it was too tight it would give a clunky feel when selecting a gear. Check several times rolling the bike forward a bit at a time in case its tight on one spot. Clean and adjust as needed. Best err on a "little" slacker if the chain does have tight spots.
