Cam Timing Marks '88 1WG Genesis
Posted: Wed May 08, 2013 9:12 pm
I'm currently in the process of swapping a new frame onto my 1988 1WG Genesis, so i thought i'd check the cam timing to make sure it was ok as the bike currently only runs well on cylinders 1&4 - 2&3 don't run very well at all.
I lined the 'T mark up on the flywheel and the marks on the camshafts don't quite line up with the dot's on the cam caps.
Hopefully these pictures are clear enough;
Inlet
Exhaust
I didn't think it was worth worrying about, until i lined up the marks on the camshafts and realised how far out the timing mark on the flywheel was;
do you think i should be worried about this? Could this be out enough to cause cylinders 2&3 to not fire properly?
Inlet
Exhaust
