Rear brake upgrade
Cueto65
Bike owned: 2xcbr600rr,Nc35
Rear brake upgrade
Post by Cueto65 »
Hi all,recently overhauled rear brake caliper on my nc35.. New pistons and seal but it's still not that good,I use the back brake quite a bit is there any other caliper that will fit and improve the braking!!! Cheers ears!!
speedy231278
Re: Rear brake upgrade
Post by speedy231278 »
TBH, that's pretty much what they are like. I did much the same on mine a few years back because I was concerned about the lack of apparent braking, but I think that's partly down the fact that there's not such a dramatic weight transfer effect when you hit the rear brake. I watched mine tested on a brake machine for the MOT last year, and my 'crappy' rear brake stuck out nearly as much brake force as the front! Did you overhaul the master cylinder as well as the caliper? There might be some gains to be had there, you never know....
bikemonkey
Post by bikemonkey »
Personally I don't think there's any point in upgrading the rear.
The front do all the stopping anyway. I just use the rear for slow speed control, and an over-powered brake set-up would surely be pointless when all it'd do is lock the back wheel.
Delboy
Post by Delboy »
Press down harder :peace:
Cammo
Post by Cammo »
bikemonkey wrote:Personally I don't think there's any point in upgrading the rear.
+1
It's crap and is only good for low speed stability.
tanto
Bike owned: NC30, Raleigh Chopper
Post by tanto »
There is one reason for upgrading the rear brake, and that is to lose unsprung weight. The standard rear brake, inc pads and fluid (I just weighed mine), weighs about 780g. An ISR 2 piston brake weighs about 500g, and if that's not enough the lightweight version weighs 240g. Factor in a custom bracket, and further weight savings from using a custom aluminium disc, if you are brave...
Incidentally, the rear brake is very useful for steep descents on the loose or wet surfaces commonplace in Thailand and, I dare say, in South Wales. :-)
For reference and drooling:
22-027 2-piston caliper, Rear http://www.isrbrakes.se/products/calipers/22-027.shtml
22-036 2-piston caliper, Light weight http://www.isrbrakes.se/products/calipers/22-036.shtml
ISR UK Importer, http://www.bikehps.com/acatalog/BikeHPS ... rs_80.html
speedy231278
Unless you're riding an RC213, does a couple of hundred unsprung grams on the rear axle actually make any difference? Cheaper and easiest to not have lunch, surely? ;-)
Morespeedvicar
Post by Morespeedvicar »
You could just go for a poo i suppose, prob loose more weight................................lol
Can you get alli discs, they sound well dodgey!!!!!!!!!!!!
Cueto65
Post by Cueto65 »
Hi all,I think your all missing the point of wanting an upgrade for the rear brake on my nc35,I'm not interested in loosing unsprung weight,I want a better brake and wanted to know if there was another caliper compatible from a newer model :peace:
Cammo
Post by Cammo »
No compatible calipers from other models. Your best bet is to flush the line, bleed with new fluid and fit new Honda (nissin brand) pads.
All a more powerful caliper will do is lock the wheel more easily, it's the geometry and weight (centre of gravity) of the bike at play here.
