NC30 sluggish - Fuel or Plugs
Posted: Mon Apr 29, 2013 1:39 pm
Hi All,
My second post and its a bit of advice required from the font of all knowledge that is greybikes.
Just bought an 89 NC30, in fair nick, however, when started it reeks of fuel, this goes away after a while, also its pretty sluggish, I will add that I just sold my GSXR1000, so its difficult for me to tell if the bike is under powered or not.
it doesn't seem to rev as free as I believe it should. From a standstill it requires a lot of clutch slip to get moving. This gets worse the hotter it gets (its not overheating). I suspect carbs or plugs. I have bought a new set of plugs in case one plug is faulty, which might explain the unburned fuel smell.
So I plan to change them and hopefully this will cure it, failing that if its carbs then my local shop said it will be a couple of hours to strip and clean. I dont do carbs, I just make matters worse
So people, any thing else I can look at.
Thanks in advance.
Thanks in advance.
