Ethos Exhaust for tackdays?
Harryredchow
Post by Harryredchow »
I have just bought an RVF400 with an Ethos twin stack full system. Do you guys have any idea on the dB levels of these setups? I have trackday booked at Bedford and it is 101dB. bit concerned I might not pass the noise test.
Cheers.
Re: Ethos Exhaust for tackdays?
Most likely louder than 101db, if theres a trackday before the 10th pop along and get it tested
Harryredchow
Cheers DM. My other bike is a KTM RC8, so I am stuck between a rock and loud place. Might borrow a dB meter and see which is quietist :)
speedy231278
Post by speedy231278 »
I still find it pathetic that such things have to be done because morons move next to race tracks and complain about the noise. Er, hello, it's a bloody racetrack!! How about not building a house right next to it...?
Or just dont rev it as hard as they ask you ;) not once has a noise tester looked at my tacho.
speedy231278
They'll keep an eye on the noise during the day. You can go somewhere on the Goodwood website and see a report of the noise measured there every day, I think. I'd be willing to bet anyone close to or above the limit during a session would be pulled and asked to submit for another test. MSV do two tests, static and ride by, according to their site. Maybe the ride by is simply a case of them having a meter or two around the track at a certain distance away that equates to the static test.... who knows?
http://www.clubmsv.com/bike-trackday-noise-limits.aspx
Not advocating circumventing trackday rules but if youve already booked something and have no time to get a new system / can to comply
These metal scourers can be bought cheap from aldi / poundland etc.
If you wrap tie some good thin wire to one and then jam it down the exhaust, leaving only a slight bit of wire sticking out near the end-can you can pass the test easily. then with some smal pliers etc pull it out on the sly.
Ive seen many people do this for mot noise tests
Harryredchow
Maybe I will just jam a couple of 'nanas up the pipe, Beverly Hills cop stylee. Cheers for the advice guys. I may get a couple of cheap dB killers just to be sure.
speedy231278
I've got a Scorpion can on an otherwise stock system, and it passes MOTs with it fitted. Can't be that loud, I suppose. Never had my collar felt for it, either.
NGneer
Post by NGneer »
A few years ago at one of the 400GB track gatherings at Cadwell 'Hipringle' came down with his new GSXR track toy - which promptly failed the noise test :(
Back to the padock and following the suggestion of one of the noise testers to "find something to muffle it a bit for the test", we had a Blue Peter moment with the foil tray from the previous nights disposable BBQ and some tywaps....
Re-tested....passed and given the required "noise tested" sticker.
I seem to recall that despite our best efforts to make sure the Tywraps were secure...the improvised DB killer subsequently eeerm ...fell off just before the first session :whistle:
:rocks:
