schoolboy error - need centre to centre of dogbone
ruffef
so i took my nc30 dogbones to the local garage who welded them up for the cost of a box of biscuits (good chaps), unfortunately i didn't measure where the new hole was to be and mark it with a punch, so i don't know where i should make the new one....
can anytone tell me the measurement of the centre to centre of the original nc30 dogbones, so i can then take 8mm off that to drill the new ones?
TVM
cheers
fred
TVM
cheers
fred
- royster81
Re: schoolboy error - need centre to centre of dogbone
113mm centre to centre -8mm = 105mm Jack up mod.
Dynamohum
Worth checking the 8mm first I've had one done moved 5mm centres and that gives a considerable jack up pretty sure I read something on here by rick oliver saying 5 or 6 mm tops
but that might just be for an 18 inch wheel.
- royster81
Dynamohum
Apologies, don't know where I got the 6mm from
Daydreaming probably..
