Won't start
Posted: Mon Apr 01, 2013 3:26 pm
FZR 400 RR 3TJ2
Sorry guys this is going to be a bit of an essay.
Last year I got this bike as a winter resto and it was not running well. Transpired that the jetting had been severely messed with. With the help of some of the clever guys on this forum I was a able to source a second set of3TJ carbs and some new seals. I then returned the carbs to original jets and settings. The net result was the bike ran and I was able to do a few miles though I never balanced the carbs as I intended doing it when I put the bike on the road this year.
Over winter I have pretty well rebuilt and refurbed the majority of the rolling chassis as it was a state - new bearings, paint seals etc etc.
I have got the bike pretty well back up together but I am having trouble starting it. It fires on 1 & 4 but will not ignite on 2 & 3. So I bought some new spark plugs having noted that the quality of the spark generally is quite poor on all cylinders but it does look weaker on 2 & 3. Put the new plugs in and still the same problem. I can't get it to start, exhausts 1 & 4 are getting warm when I try to start it but I can't get 2 & 3 to fire so it won't run.
Things I should declare to help with diagnosis--
Not renewed coils or HTs
Have disconnected and reconnect the wiring harness during the refurb.
Fuel pump is working
Reserve wiring is disconnected
All cylinders are getting fuel
Carbs have not been balanced but it ran before
New plugs
Battery good
Earths cleaned
My questions are --
How do I check the coils ?
How do I check that I am getting the correct voltage to the coils?
Can I replace the HT leads - they look like they a bonded into the coils?
How do I check the igniter?
Does anyone have a clue - I have reached a blank!
Happy Easter?
Thanks in advance.
Mang
New plugs
Battery good
Earths cleaned
My questions are --
Happy Easter?
Thanks in advance.
Mang
