Page 1 of 3
Suzuki GSXR400SPII Airbox sensor/carbs
Posted: Sun Mar 31, 2013 7:52 pm
by guitarman
Hi,
Could anyone help with a project Iv just purchased it a SP version of this bike but its has come in boxes, Im having trouble with the loom. There is a sensor on the top of the air box that has two pipes coming from it and Im not sure where the pipes should go.
Please see attached photo
What are all these pipes joined to?
A(purple) top of airbox?
B(yellow) ??
C(Lime green)??
D(Red)??
What is the part circled in red?
Re: Suzuki GSXR400SPII
Posted: Sun Mar 31, 2013 11:05 pm
by 4hundread
H
Posted: Mon Apr 01, 2013 6:45 am
by Gimly56
Post up a photo if you get a chance buddy & I might be able to help? I've just sold my SP version GSXR250 and they're very similar to the big brother 400.
Posted: Mon Apr 01, 2013 3:40 pm
by slo12
air pressure sensor. I need one as well
Re: Suzuki GSXR400SPII Airbox sensor
Posted: Wed Apr 03, 2013 8:34 pm
by Variablevalves suck
The two pipes should run to a white nylon junction that then splits into 4 pipes that attach to the side of the float bowls.
The valve on the airbox is opened and closed in relation to TPS and revs and pressurizes the float bowls.
Posted: Wed Apr 03, 2013 9:41 pm
by Gimly56
I concur. I had to buy a brass joiner to connect the hoses to the 4 carbs as mine was missing.
Posted: Wed Apr 03, 2013 11:07 pm
by guitarman
Variablevalves suck wrote:The two pipes should run to a white nylon junction that then splits into 4 pipes that attach to the side of the float bowls.
Could you please take a look at the photo Iv attached to the post and help me sort out the pipe problem.
by guitarman
Gimly56 wrote:I concur. I had to buy a brass joiner to connect the hoses to the 4 carbs as mine was missing.
Posted: Wed Apr 03, 2013 11:35 pm
by 4hundread
P
Posted: Thu Apr 04, 2013 8:13 am
by Gimly56
You can connect some hoses to 'A' and simply have them hanging down into space. I did that on mine and it ran fine. They're only breathers and you can possibly get away with not even connecting any hose to them?
