NC30 intermittent/week spark
Bigtomo71
Hi there
Quick 1 for ya
Ive just done the valve clearances on my friends nc30 as he was finding it hard to start unless he pushed it with the start button. the clearances had never been done! there was no clearance at all on the front 2 cylinders. Also fitted a new clutch while i was at it.
We went to start it after an it still wouldnt fire. Unless you pushed it an then it sat an run fine an took it out on a 40 mile ride. runs fine other then a flat spot between 5-8rpm then it kicked an flew. stopped the bike an it wouldnt start. took 1 of the plugs out an hit the starter an it wouldnt fire for a few seconds then it would spark but very week. Ive tried fitting another CDI an coil packs but still no good. cleaned up the contacts on the coil packs but still no good.
Has any 1 else any ideas as to what could be up with it as he needs to get it sold as hes leaving the country in a few eeks an need to get it sold!
Thanks for any help!
Cheers steve
Quick 1 for ya
Cheers steve
- Bike owned: VFR400
Re: NC30 intermittent/week spark
You need to remove one of these posts, should not be in both workshop and general.
