First post - standard colourscheme pictures
Posted: Thu Oct 09, 2008 9:06 pm
After months of looking I bought a NC30 from fleabay, 296 miles away. It was rough, had been down the road and was cheap. It's a late N model with 15km on the clock
When I finally got it home, it's been ripped to pieces, Ive re-sleeved the yanagawa??? end can, stripped the forks to replace a seal and found that one had been straightened.
The front wheel is from an early model, as are the forks and the motor isn't original but runs ok and valve clearances are spot on.
all parts replaced, straightened, shot blast, re-finished, greased and carassed where necessary and I'm getting close to doing the bodywork...hence this post.
It's a almost stock red and white paint scheme and was a good job pre accident.
Tank is scrapped,seat unit fine but scratched, tailight plastic infill panel missing, spare top fairing supplied with the bike in grey, fairing sides gouged and scratched.
I quite fancy RC30 colours but the wheels are black and that's how I like them, so are there any pictures of stock colourschemes on here that I can use for inspiration, if I get no inspiration it will be flat black.
Cheers dudes!
Cheers dudes!
