GK76 rear shock fitments?
Posted: Thu Mar 14, 2013 4:08 pm
by topfridgeman
Hello,
Does anyone know which other rear shocks with fit or very nearly fit the gk76 model gsxr?
Thanks, Col.
Re: GK76 rear shock fitments?
Posted: Fri Mar 15, 2013 12:43 pm
by DirtMcGirt
Posted: Mon Mar 18, 2013 12:18 pm
by dsr91
i fitted a k7 rear shock to mine with 20mm jack up link arms from projections , you dont need the jack up kits to fit them tho , but if you do buy a k7 shock try to find one that has the gas adjustment thing at 90 degree angle sat on top the shock , it makes it much easier to fit and no need to modify battery tray or airbox but you willl need to modify bottom linkage a little bit only takes 30seconds to modify ,also k7 shock is same hieght as standard one .
Posted: Thu May 30, 2013 9:11 am
by gsxrkev
gsxr k7 600 shock?
Posted: Thu May 30, 2013 9:40 am
by dsr91
gsxrkev wrote:gsxr k7 600 shock?
I believe 600 fits the same but I brought a k7 ,750 shock from 2009 bike
