NC30 master cylinder
scotjell
- Bike owned: VFR400 NC30x2
Ok as above mine is leaking. It's a 14mm o/d is this the same as the 24s? I believe the 30's are 12.7 not sure when they changed I just want to confirm.
Re: NC30 master cylinder
The NC30 is a 14mm dia, i believe the NC24 was smaller as i bought a cheap kit off ebay to replace the damaged boot, and the NC24 seals were much small im sure.scotjell wrote:Ok as above mine is leaking. It's a 14mm o/d is this the same as the 24s? I believe the 30's are 12.7 not sure when they changed I just want to confirm.
scotjell
Just can't find one ATM. A guy on the forum mentioned they are 14x50.5. I need the repair kit.
What for the 30 or the 24 if you after the 24 one you can have what bits i have herescotjell wrote:Just can't find one ATM. A guy on the forum mentioned they are 14x50.5. I need the repair kit.
- NGneer
Scott
Have a look at this thread...viewtopic.php?f=24&t=40670
Honda changed from somthing like a 5/8" master cylinder to a 14mm master cylinder so there are two kits available depending on what size master cylinder you have. Not sure what size the NC24 stuff is and if it is compatable.
Graeme France would be my suggestion if you need a (decent quality) refurb kit.
scotjell
Sorry chaps the title did say NC30 lol. Unfortunately RO hasn't got any pattern ones and Mr H is a bit pricey. I'll give Graeme a go I think. Some dealers have been really helpful and measuring one being a bloke in Southampton called John Oldfield.
