Will other carbs fit my gk76
dsr91
Bike owned: gk76a , 92
Post by dsr91 »
To start of my 92 gk76a spends more time off the road than it does on it , all because of there famous carbs , I hate them with a passion now , I have just replaced o rings and took carbs to tuning place to have float heights done and now my bike is worse I give up now , and can't find any replacement gk76 carbs anywhere ! So my question would be will others models fit , bandit , early gsxr 400 or something else completely like yamaha ? Any ideas
Variablevalves suck
Re: Will other carbs fit my gk76
Post by Variablevalves suck »
You can only fit horizontal carbs to the gsxr.
Most of the other 400's have downdraft and will not fit.
The best thing you can do is post your problem and people will try and help,
The o'ring problem is usually rich running and any other issue will be something else.
dsr91
Post by dsr91 »
Cheers vvs I think these carbs are beyond it tonite 3 out 4 caps have cracked , I'm very tempted to put any carbs on it and make a intake manifold or this one is my favourite idea sell it and buy a fuel injected 636 , umm is there replacement caps available for gk76 ?
dsr91
Post by dsr91 »
Does anyone know the model off carbs that are on gk76 a ? ?
rgvsp
Bike owned: RGV250SP (VJ23) GSX-R400R
Post by rgvsp »
Mikuni BST33SS (35SS for SP)
dsr91
Post by dsr91 »
Do they change style over the years ? Because I read that gsf/katana use bst33ss but they look different, all I can find that may get my bike running is a set off bandit 400 carbs but I don't know if they have 2 fuel lines like gk76 plus there intake look alittle different so think it may need cone air filters
Variablevalves suck
Yes the carb is different after 89, think the closest carb is the 35mm RF600.
As i understand it the carb is the same casting with a different bore, if you can drop on a cheap set the tops should fit.
dsr91
Post by dsr91 »
If I was to buy a complete set of rf600 Carbs do you think it would be possible to bolt it straight on and have bike running , I would probs have to down jet it I would of thought , but I really need these bike back on the road my other bike is also having trouble so soon I'm going to be without transport cheers
dsr91
Post by dsr91 »
Right update time , my bike is f@@ked I brought rf600 carbs and used the tops to replace my damaged ones , so far then , orings replaced , floats set to spec listed on here at 20.5 new carb tops , new oil etc and its not even starting , plugs have good spark , feul getting to carb bowls but I don't believe it's getting throught carbs ? Any ideas anyone
Variablevalves suck
If you have a strong spark and the pilot system is clean the bike should start.
Are the plugs wet or dry?
If they are wet then carefully check the electrical side out.
If dry you need to look at the pilot system and choke.
You can have a play about with the RF carbs and figure out exactly how the pilot system works.
You will have air going in through the pilot air jet at the front of the carb and fuel coming up through the pilot jet, this is then feed through the small hole that the pilot screw opens.
People bang on about the carbs on the gsxr but they are no different to any other 20 year old 400.
If everything is ok the bike will start so take your time.
