radiators
john alex
radiators
Post by john alex »
hi can enyone tell me best paint for painting radiators
Re: radiators
You rarely see them painted...and I suppose that was to be sure they work more efficiently..which is the point ;-)
speedy231278
Re: radiators
Post by speedy231278 »
Lower rads for 30/35 are painted black.... uppers are left in the natural state. No idea why they're not both the same...!
stutto
Re: radiators
Post by stutto »
Maybe corrosion resistance is more valued on the lower rad, due to crap getting flung towards it from the front tyre?
stutto
Re: radiators
Post by stutto »
Also, IIRC, the lower rad has copper fins, whereas the upper seems to be constructed differently so possibly different materials too?
speedy231278
Re: radiators
Pretty sure the lower is all ali. It certainly seems silvery when the paint and fins flake....
hunter
Re: radiators
Post by hunter »
Yep they are both ali.
stutto
Re: radiators
Post by stutto »
OK, wrong again! It wasn't easy to tell what mine was originally made from when it came off...
For some reason the coolant temp rose quickly when stuck in traffic.... :whistle:
hunter
Re: radiators
Post by hunter »
A lick of paint it will be as good as new. :smile:
speedy231278
Re: radiators
Be VERY careful if you try to take the fan off. When the rad looks like that, you often find the brackets are returning to nature and are corroded and splitting. The fan shroud retaining bolts often get corroded into the brackets, and the just rip off. Been there, done that, even holding the bracket to try and minimise the load on it. Bottom rads seem to be fairly common on eBay, you might find a healthier one. I got a belter just over a year ago for not very much, and it was near mint.
