Voltage Regulator - Are they a weak point?
Clanky
Bike owned: FZR 400 3EN1, FZR 600 3HE
Post by Clanky »
Hi,
Are the regulators/rectifiers on the FZR400 a weak point? I have a FZR600 and upgrading the VR to a later finned one from a YZF600 is a highly recommended mod. The old style are prone to failing and burning out.
I'm working on my 400 doing some work towards the MOT so while I have things apart this would be a good time to swap the VR out if it has the same issues.
If anyone has done this are there any problems with locating the newer type VR?
Re: Voltage Regulator - Are they a weak point?
Post by Evilchicken0 »
I've heard of one going and I've been on here for about 8 years. The reg rec isn't a problem.
I wasn't aware it was a problem on the 600 either, they're the same charging circuits although the batteries are slightly heavier on the 600. Sounds like somebody has had a scare and spread it round, I know Hondas have weak electrics and they use the R6 unit.
Clanky
Post by Clanky »
Thanks Evil,
On the 600 forums there's a lot of talk about failing VRs and guides on replacing them. My 600 had a fried VR so I am inclined to think there's something in it, but it may be more to do with the way they're mounted on the 600. Like you say both bikes use the same VR.
I couldn't find any threads on here about it so I guess it isn't a common problem on the 400s.
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
I've only ever come across one Yamaha reg/rec failure, ironically on my own R6 :roll: Turned out to be a fried generator causing the problem - the cover gasket had let in a bit of water.
willandrip
Post by willandrip »
There does seem to be a high number of failures of the 600 v/r esp on the US forums.
The fault is traced to a bad earth system (shunt type V/R's must be adequately earthed to prevent heatbuild up and consequent failure)
The original 600 unit is earthed through one of the mounting bolts to an alloy heatsink plate bolted to the steel subframe that then bolts to the main frame.Some have an additional earth tag at the V/R fixing that is part of the harness.Galvanic corrosion between the alloy heatsink and the steel subframe appears to be the units demise as it is also shielded from airflow by relays and the seat sidepanels.
If the earth path is good there is no reason to doubt the V/R on either 400 or 600.
The upgrade advised uses a later V/R with its own cooling fins and is not shunt regulated.
600 3HE
400 SP 2TK
Notice the earth tag on both at the fixing.
I reckon the problem is compounded by new owners reviving non runners, after corrosion has degraded the earth path with them standing and the V/R fails within days of first use.
If they do fail all manner of electrical problems ensue so owners tend to upgrade.
The later 3EN 400 models have the reg res mounted on the frame above the swingarm pivot. The 3TJ moves it up a bit.
Maelstrom
Bike owned: MC22, 3TJ1
Post by Maelstrom »
I read some good material on a forum about the shunt style units overheating but I cannot recall where it was.
If you google this it comes up with kits that some sells on ebay.
SHINDENGEN MOSFET FH012AA REGULATOR/RECTIFIER KIT
Might be useful for future reference.
https://litetek.co
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Post by Hogdigerdy Dog »
the 3TJ is also the finned variety for better cooling,
Clanky
Post by Clanky »
Thanks for the replies.
Does seem that the earthing and heat dissipation are big factors.
Here's a link to one of the 600 forums discussing the issues and fixes:
http://fzronline.com/wiki/doku.php?id=r ... conversion
Hogdigerdy Dog
Clanky wrote:Here's a link to one of the 600 forums discussing the issues and fixes:
the reg/rec they say DO NOT USE in the 3rd picture down, looks identical to the 3tj jobbie
