Brembos fitted
bollo
Brembos fitted
got my Brembo's i bought from Italy also got the fitting kit from SES race parts in the UK
still got to bleed them & lock wire as this is a race bike
bollo
Re: Brembos fitted
using the standard master cylinder, i have a nice Brembo radial but because i race in a period class can't use i was told as no road bikes had them in the period, do you know of a better master cylinder i could use that's not radial ?
Re: Brembos fitted
I dunno.
Best to use one from a bike that uses those calipers, aprilia rs250, ducatis etc.
bollo
Re: Brembos fitted
hmm ok the calipers came from a Ducati i'll look into it cheers again Cammo
PS get on facebook Cammo so much easier for me to get info from you lol
amorti
- Bike owned: CB-1, MSX125
Re: Brembos fitted
A 98-9 cbr 900 master looks very similar to stock but is the right size.
I used a cagiva planet brembo master on my cb-1 and the lever clashed with the control pods. Could also be an issue with a stock duc master.
If you want it the 00-03 cbr 900 master was another technological step forwards, the last word before radials came in.
All the above will work well with big 4 pots, your stock master will have over long throw and be a bit vague in feel. But it will work and give great braking power from two fingers, if that doesn't trap your other fingers under the lever.
bollo
Re: Brembos fitted
amorti wrote:A 98-9 cbr 900 master looks very similar to stock but is the right size.
Hi Amorti
do you know if the vfr400 lever will fit either of the master cylinders you recommended ? i lashed out & bought cnc levers already to fit the vfr400 master cylinder
& thanks a heap
cheers Allan
bollo
Re: Brembos fitted
ok thats great cammo , another thing just want to confirm s ifi go the 2000 / 2003 master cylinder it will gve good feel & less movemen at the lever ?
bollo
Re: Brembos fitted
well i guess now i just have to find a master cylinder now from a 00 / 03 Blade, after looking on ebay apears not that easy
