NC29 cbr600 shock where to mount gas canister?
1308lee
Bike owned: CBR 125 Followed by my NC29
Post by 1308lee »
Got the shock ready to be fitted and was wondering where to mount the gas preload adjuster? Is drilling and tapping the swing arm a silly idea? It's on one of those flexy cable things :) any advice welcome :D
vr46
Bike owned: All sorts
Re: NC29 cbr600 shock where to mount gas canister?
Post by vr46 »
Exhaust bracket, secured with decent cable ties.
Skint Novice F400
Bonzo
Bike owned: CBR400RR NC29
Post by Bonzo »
I managed to get mine in the storage bit, under the rear seat. Keeps it clean and not exposed to the elements.
1308lee
Post by 1308lee »
so, is drilling and tapping my swingarm and making a bracket for it a bad idea?
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Unsure what you mean by this as the swingarm flexes up and down and could catch the hose to the gas canister on another part of the bike and damage the hose/canister or punt you off down the road.
You could ruin a perfectly good looking swingarm, ive done it like this, its safe and secure and easily accessible although the rear pillion pegs can be a pain to use if needed.
paulmac
Post by paulmac »
cbr400rrn wrote:Unsure what you mean by this as the swingarm flexes up and down and could catch the hose to the gas canister on another part of the bike and damage the hose/canister or punt you off down the road.
You've obviously got the longer hose shocker. I got the shorter hose model and managed to remove the little bracket under the seat/tank that holds a couple of wiring connectors. I just cut it off, but kept the part that holds the front screws for the sidepanels. Then I managed to mount it longitudally along the frame.
I'll try to get a pic :peace:
BTW longer hose variant is the better bet , but I got a really good condition shock so it was worth the hassle, alterring the pivot linkage to get the right ride height was the tricky bit
mattj92
Bike owned: Nc30 build in progress
Post by mattj92 »
http://m304.photobucket.com/albumview/a ... 9&newest=1
I just cut down an old exhaust hanger and bolted it on with a longer bolt at the chain guard mount. Worked fine for me
