What bulbs are the nc30?
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
Just done the relay mod for low beam on the vfr, bought some H4 55w bulbs but they don't fit, what Is the fitting?
bikemonkey
Re: What bulbs are the nc30?
Post by bikemonkey »
H4R is standard, I think you have to mod the headlight a little bit, was covered recently in another thread, but I forget which......
CRM
Admin NWAA
Admin NWAA
Post by CRM »
they need some modification to fit, the jap spec bulbs have different tab locations to the default H4 bulb.
so either snip the 2 lower tabs to suit, or try and source a pair of UK spec headlamps.
Bike owned: VFR400
Post by magg »
Yes. The bulbs need modifcation.
The lower two tabs are in the wrong place.
You can either
1. Cut the lower tabs off and fit re-usbable H4 adapter rings (about 6 quid)
2. Bend the tabs inwards and use a nail to steady the bulb.
3. Dremel the plastic around the headlight to fit the H4 tabs
speedy231278
Post by speedy231278 »
Not sure about the 30, but on the 35 there's also a small semi-circular notch that needs grinding out of one side of the flange on the lamp by a few mm for it to sit level. Not sure if the adapter rings negate this requirement, I haven't got around to fitting them yet.
Edit: just found this that explains the notch, and also shows the difference in the legs on the headlamps....
