3TJ gear shifter question
- Kayla850
- Bike owned: Sunn Tzar S2
Is the rod end on the gearbox shaft (ie not the rod end that's attached to the gear lever itself) left hand or right hand thread? I haven't got a complete 3TJ to hand to check. Ta.
www.projection-racing.com
www.pjcfasteners.com
Re: 3TJ gear shifter question
Hi Kayla;presuming you are on with the rearsets?
The pedal rod is threaded right hand at the gear change clamp rose joint and left hand at the pedal rose joint..
This is true of all Yamahas.
- Bike owned: fzr600-,yzf750-,owo1,750
correct
I thought all bikes were like that, I guess they could be the other way round though. it wouldn't work if they were both the same
- Kayla850
Brill, thanks!
Bill, yes I'm on with the rearsets now- we're getting there, poco a poco as they say in Spain!
Any idea of prices?
