Gear selector shaft seal
Willcox
- Bike owned: 1989 NC23
Does anyone know if you can change the gear selector shaft seal (on a nc23) without stripping the engine down and removing the shaft?
- Variablevalves suck
Re: Gear selector shaft seal
I dont have a cbr BUT if you can see the seal you can replace it.
Willcox
ah cool I thought that was the case
Ive done by gently tapping something sharp through the seal and flicking it out, careful as there is usually a small 'c' clip behind.
Willcox
Yea I've done it now, used a self tapper, screwed it in then just pulled it out with a pair of pliers, then tapped the new on in
