compression testing nc30
stefan
- Bike owned: nc30
hi can anyone help me out i am trying to find a 8mm adapter so i can check the compression of my engine but it seems that no one in the UK sells one can anybody help thanks.
- alexwitham
Re: compression testing nc30
I am also finding it difficult to obtain an adapter so am having to make one using an old plug.
arsey30
- Bike owned: ftr223 650 bros
I use one with no thread, just a rubber bung type seal, Gunson
Sealey ct 954 similar, but unsure of length.
stefan
- Bike owned: nc30
thanks for the replies i have tried to make an adapter from a spark plug but not having much luck on getting a air tight seal, also struggling to get a good enough seal with the push on tester. i have heard that an adapter can be made i just don't have the tools to make one has anyone been able to make one.
- Lane
- Bike owned: MC21,MC22,NC35's,VJ22
I made one out of an old spark plug with the porcelain removed and a pipe brazed on with a female thread at the top to screw the 10mm compression tester adaptor into.
I also have a rubber push fit one which works just as well, however it takes a couple of attempts to get the seal right.
stefan
- Bike owned: nc30
What psi readings were you getting with the push on type tester
That looks just like my old gunson from the 80s!arsey30 wrote:I use one with no thread, just a rubber bung type seal, Gunson
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
A machinist made an adaptor for me, I'll post photo and details when it arrives.
- Lane
It's a freshly rebuilt engine that had 0.5mm skimmed from the heads and has 220 psi on all four pots, rings and cylinder walls aren't bedded in yet.stefan wrote:What psi readings were you getting with the push on type tester
