Fitting preload fork tops to NC23
Willcox
- Bike owned: 1989 NC23
Has anybody on here fitted nc29 preload fork caps to nc23 forks if so what internals need modifying, any help would be great
stimpy
Re: Fitting preload fork tops to NC23
Early nc29 tops(without rebound adjuster) go straight on.
Stimpy
Stimpy
Wozza
You might need to cut down the spacer tube.
amorti
- Bike owned: CB-1, MSX125
Also caps with damping adjusters will work if you cut the damping bit off on the inside.
