Bens Race Bike Build / 2015 race season
Posted: Thu Jan 10, 2013 6:13 pm
So i've decided to take the plunge and start racing this year with NG Road Racing!
I bought myself a zxr 400 track bike, and now it just needs prepping, im going to give it a bit of a strip down hopefully not to find some horrors lurking underneath, just to make sure everything is ok and ready to go
Here's how it looked when i picked it up.
It also come with spare fairings, and a ram air kit.
Once i got it home i starting with getting all the stickers off the fairings as they will be getting resprayed before the start of the season (hopefully
some were a bit more stubborn than others
then went onto removing the bodywork as the exhaust has a slight blow which i needed to find.
radiatior has been modded to accept ram air kit
Also found the steering damper was fitted so the rod came dangerously close to your knee
, swapped it around, jobs a goodden.
Made a start at sanding the fairing, to be honest i didnt need to take all the paint off so have just keyed up the rest and will get some 600 and 1200 grit on it before its sprayed.
Exhaust has a few blows around the collector area and the can needs cutting down slightly and re-rivetting as its split from a drop.
May be on the lookout for some sort of race system in the near future (micron, BEET etc)
but for now father will weld it up.
So thats it for now, next on the list is to drain coolant and get the rad off for a clean up, so will post updates soon.
