Nc35 jack up linkage question
steve92
Post by steve92 »
I'm was thinking of modifying my nc30 linkage so it gives the same amount of rise the nc35 one gives.
So i'm right in thinking the holes need to be further apart.?
Does anyone know the distance between the hole centres on the nc35 linkage.?
CRM
Admin NWAA
Admin NWAA
Re: Nc35 jack up linkage question
Post by CRM »
7mm closer gives an extra 2.5" if i recall correctly. could be wrong like, but its closer not further.
You will need to mark the new hole, then weld up the old one before drilling the new hole as they overlap.
steve92
Post by steve92 »
Ok 7mm closer. Hopefully someone will confirm its 7mm before i start it.
Yea i remember there was one forsale a while ago and you could see how they over lapped.
:rocks:
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Aye, shorten dog bone length to raise the rear, longer bones for short arses :lol:
CRM
Admin NWAA
Admin NWAA
Post by CRM »
i got it slightly wrong see here
viewtopic.php?f=22&t=34241
steve92
Post by steve92 »
I see the nc35 one raises the back by 18mm and Ricks by 36mm.
Wonder should i make mine like Ricks.?
Is the nc35 linkage a worth while upgrade with the 18in back wheel.? i guess this is why rick does the 36mm one to give the same effect with the 17in wheel.
Cammo
Post by Cammo »
steve92 wrote:I see the nc35 one raises the back by 18mm and Ricks by 36mm.
It depends what you want, a slight raise (by fitting the rvf link with 18" wheel) or the full monty 36mm lift. The full lift gives quicker steering. I've done it to all nc30's I've owned - not a fan of the standard arse-dragging slow steering.
steve92 wrote:i guess this is why rick does the 36mm one to give the same effect with the 17in wheel.
Not really, Rick's 36mm lift is designed for nc30's with the 18" wheel. On rvf's you can add a shim to the top of the rear shock for the same effect (Rick sells these also).
HTH
