fitting a Mychron 4 , 2T dash to my NC30
bollo
Post by bollo »
Hi guys my brother & I are in the process of fitting my mychron 4 2T to my NC30, not as easy to cut carbon fibre & get right buy not to bad so far what do you all think ?
the toggle on the left replaces the key & the green light is the neutral the red the oil , still got a little work to finish also need to wire up all the new bits as in the red starter button on the right then left thats off a Honda RS125 run / off switch
vfrman
Bike owned: NC30, 1098s
Re: fitting a Mychron 4 , 2T dash to my NC30
Post by vfrman »
Looks nice. Can you take a side pic of that steering dampner? I am curious how close the other end comes to skewering you in the leg!
Aye turn that damper round, it makes me cringe when i see them mounted that way :o
Neat dash install tho :peace:
Hanton31
Post by Hanton31 »
Nice dash, where is it from or have you made it that setup??
I need me one of those for my race bike!!
bollo
Post by bollo »
Hanton31 wrote:Nice dash, where is it from or have you made it that setup??
google mychron 4 2t there from Italy i have used this dash on numerous bikes over around 6 years
Hanton31
Post by Hanton31 »
Cool thanks!
Are they pretty self explanatory to fit or??
bollo
Post by bollo »
very easy it's just a bolt that holds the dash then you can run whatever sensors you like , this is a 2 sensor dash well i'll clarify that you can read 2 of the sensors on the dash as well as all sorts of other stuff so i am running water temp atm & i am not sure what else to run but you can add as many & log them as you want
bollo
Post by bollo »
hi drunk monkey the steering dampner is off a Honda RS125 so it is not as long as what you would prob have , i made the bump stops longer to accomadate , i mean it's a race bike so not going to need full lock anyway & i got a trick WP adj dampner from a mate
