tyga magot pipe
jpd748
tyga magot pipe
Post by jpd748 »
I have a Tyga system with a magot end can and yes it is TOO loud. Has anyone done any tricks to quieten it down? :pray:
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: tyga magot pipe
Post by jim157 »
Get a different end can. There's not much you can do to quiet a maggot, straight from the horses (Paul from Tyga) mouth:-
viewtopic.php?f=17&t=39337&hilit=tyga&start=10
AUTOEXEC.TWAT
speedy231278
Re: tyga magot pipe
Post by speedy231278 »
It's funny what people consider loud. I've got a Scorpion can, and that's pretty tame. Having said that, I don't think an NC is all that loud even if you're antisocial and run it on the drive with the old can off to see what it sounds like.. ;-) Now, a 1000/1200 of Ducati with big bore pipes and carbon Termi cans... that's LOUD!
Morespeedvicar
Re: tyga magot pipe
Post by Morespeedvicar »
You should of heard me nc with two reverse cone megas on, now that was loud! Made me ears ring after half hours riding, but even tho it was loud it sounded great!
Anyway can you weld in a removable baffle cos i dont think you can get a bolt in one? May help a bit.
Ian
speedy231278
Re: tyga magot pipe
Why not see if someone else with a Tyga system wants to swap a quieter can?
jpd748
Re: tyga magot pipe
Post by jpd748 »
tks Speedy, that's probably the way to go. Any guys in the forum in Australia who may want to swap?
Otherwise, what do you guys consider a good end can?
Cammo
Re: tyga magot pipe
Post by Cammo »
Another tyga end can would be easiest and you know it will go on with no problems. Only the maggot is loud in their range, all the others sound good.
http://tyga-performance.com/site/index. ... 036_83_150
iDemonix
Bike owned: '92 NC30
Re: tyga magot pipe
Post by iDemonix »
I've got a maggot on mine I just fitted with full system, tis a touch loud!
vr46
Bike owned: All sorts
Re: tyga magot pipe
Post by vr46 »
I've got a big bore can for an NC35, it's loud but has a nice removable end cap insert which narrows down the outlet quite alot. Possibly a machine shop could make the same for yours?
Anyone ever had twin magg's on an SP1 style system? :shock:
Skint Novice F400
laurence_13
Re: tyga magot pipe
Post by laurence_13 »
If you're getting rid of the can I'll happily take it off your hands :)
