Nc30 carbs - emulsion tubes
vic-vtrvfr
Hi folks
Just wanted a quick check, the emulsion tubes with 4 holes go to the front while those with 5 holes go to the rear?
I'm asking cos I just stripped set of carbs that I'm hoping to use on my bike & they were the other way around.
Mind you, they also had both left hand main jets at 115 & both right hand at 118. Logical...
Thanks as always
Vic
Thanks as always
Vic
- speedy231278
Re: Nc30 carbs - emulsion tubes
Yup, 4 front, 5 rear. Now, as for where the bigger jets go, well that depends on whether you read the Honda parts diagram or go by whatever everyone else on here does... I'm glad the 35 uses the same size all round... lol
vic-vtrvfr
Cheers for that. I'm happy enough that the 115 should be at the fronts, 118 at rear.
Whoever built these before must've got a bit confused :)
