NC30 rocker arm spacer, not spring? anyone know why?
Posted: Sun Dec 30, 2012 5:36 pm
by laurence_13
Doing the valve clearances on my nc30 and in the haynes manual, it says you should be able to push the rocker arm across taking up the tension of the spring so you can get the shims out, however, mine doesn't have a spring it's just got a spacer? Is it just a different year engine or something?
Re: NC30 rocker arm spacer, not spring?
Posted: Sun Dec 30, 2012 5:48 pm
by pip
Eh, no idea what has happened there!
Are they all like that?
Pip
Posted: Sun Dec 30, 2012 5:56 pm
by jetblack
pip wrote:Eh, no idea what has happened there!
Pip
Mine defo has springs on all the rockers. I moved them across and wedged a socket in to hold them back whilst i swapped the shims out
Posted: Sun Dec 30, 2012 6:59 pm
by bikemonkey
Mine also has springs on them all, I used a screwdriver to hold mine back.
Maybe it's an ex race engine or something? Someone will know :up:
Posted: Sun Dec 30, 2012 7:41 pm
by laurence_13
hmmm, odd! yep they're all like it
I got the engine off ebay it's not the one that came in the bike the original engine has springs could i swap them back? is there any other v4 imports that might have them?
Engine number is; NC13E-1210796.
also probably worth mentioning that the spacers aren't a perfect fit around the shaft, the internal diameter of them does not match the external diameter of the shaft
Re: NC30 rocker arm spacer, not spring? anyone know why?
Posted: Sun Dec 30, 2012 8:10 pm
by thunderace
I think someone has had the engine apart and lost the springs......
Posted: Sun Dec 30, 2012 8:16 pm
by laurence_13
thunderace wrote:I think someone has had the engine apart and lost the springs......
haha, seems most logical seeing as they aren't a perfect fit, best to just stick the springs back in then?
Posted: Mon Dec 31, 2012 1:34 am
by hunter
I be wright,I think someone has been looking at old tuning methods,But by the sounds of things hasn't done a very good job, Many moons ago when we used to tune triumphs the rockers had a spring on the shaft,
We used to remove the spring and fit bronze spacers,These would give less resistance to rocker movement.
Less drag more horse.
Posted: Mon Dec 31, 2012 11:21 am
by scotjell
If your interested I may have a full set of springs how many do you need?
Posted: Mon Dec 31, 2012 11:58 am
by laurence_13
hunter wrote:I be wright,I think someone has been looking at old tuning methods,But by the sounds of things hasn't done a very good job, Many moons ago when we used to tune triumphs the rockers had a spring on the shaft,
interesting, if thats the case they've done a pretty poor job
scotjell wrote:If your interested I may have a full set of springs how many do you need?
I'm ok for them thanks mate, its a replacement engine so can just take the springs out the old one, cheers anyway
