NC30 rocker arm spacer, not spring? anyone know why?
laurence_13
Doing the valve clearances on my nc30 and in the haynes manual, it says you should be able to push the rocker arm across taking up the tension of the spring so you can get the shims out, however, mine doesn't have a spring it's just got a spacer? Is it just a different year engine or something?
pip
Re: NC30 rocker arm spacer, not spring?
Eh, no idea what has happened there!
Are they all like that?
Pip
Pip
- jetblack
- Bike owned: '89 NC30 SEED
Mine defo has springs on all the rockers. I moved them across and wedged a socket in to hold them back whilst i swapped the shims outpip wrote:Eh, no idea what has happened there!
Pip
- bikemonkey
Mine also has springs on them all, I used a screwdriver to hold mine back.
Maybe it's an ex race engine or something? Someone will know
laurence_13
hmmm, odd! yep they're all like it
I got the engine off ebay it's not the one that came in the bike the original engine has springs could i swap them back? is there any other v4 imports that might have them?
Engine number is; NC13E-1210796.
also probably worth mentioning that the spacers aren't a perfect fit around the shaft, the internal diameter of them does not match the external diameter of the shaft
- thunderace
- Bike owned: R6, YZF600R
Re: NC30 rocker arm spacer, not spring? anyone know why?
I think someone has had the engine apart and lost the springs......
laurence_13
haha, seems most logical seeing as they aren't a perfect fit, best to just stick the springs back in then?thunderace wrote:I think someone has had the engine apart and lost the springs......
hunter
I be wright,I think someone has been looking at old tuning methods,But by the sounds of things hasn't done a very good job, Many moons ago when we used to tune triumphs the rockers had a spring on the shaft,
We used to remove the spring and fit bronze spacers,These would give less resistance to rocker movement.
Less drag more horse.
scotjell
- Bike owned: VFR400 NC30x2
If your interested I may have a full set of springs how many do you need?
laurence_13
interesting, if thats the case they've done a pretty poor jobhunter wrote:I be wright,I think someone has been looking at old tuning methods,But by the sounds of things hasn't done a very good job, Many moons ago when we used to tune triumphs the rockers had a spring on the shaft,
I'm ok for them thanks mate, its a replacement engine so can just take the springs out the old one, cheers anywayscotjell wrote:If your interested I may have a full set of springs how many do you need?
