Hello and Removing swingarm and rear wheel.
talcumpowderbut
Post by talcumpowderbut »
Hey guys, first time on here, so. I'm Connor, 19 and from Scotland. i own a nc30 and here is how it stands atm.
Anyway. i was tightening the exhaust down pipes onto the rear manifold and the stud on the manifold snapped. So i am going to replace the manifold ( it has seen better days anyway ) I read that you can get access by removing swing arm, i dont want to drop the engine out if i dont need to. So my main question is, What general tools do i need to remove rear wheel and swing arm? i.e. size of sockets, any castle shaped sockets? Any help would be appreciated and nice to meet you all! :peace:
Dynamohum
Re: Hello and Removing swingarm and rear wheel.
Post by Dynamohum »
36mm for rear wheel and you can get the castellated tool from ebay. Removing the manifold can be done with the swinging arm in place but it's tricky getting to the nuts on the exhaust ports . Unbolting the subframe might help a 1/4 drive socket set with flexible adapter is what most guys on here use. Would give the nuts a good douse f penetrating oil and take your time as they can easily snap.
talcumpowderbut
davethetrucker wrote:36mm for rear wheel and you can get the castellated tool from ebay. Removing the manifold can be done with the swinging arm in place but it's tricky getting to the nuts on the exhaust ports . Unbolting the subframe might help a 1/4 drive socket set with flexible adapter is what most guys on here use. Would give the nuts a good douse f penetrating oil and take your time as they can easily snap.
Thanks alot mate, flexible adaptor sounds like the ticket!! Cheers ma man. 8-)
I removed mine without taking the swinger off.
Removed the front sprocket cover too as that helps..and also loosened off the subframe to get access. As already said - flexy adapters help a lot - as do 6 sided sockets, instead of 12 pointed.
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
As Mark says, get a 6 point socket (walldrive are epic) and a knuckle/flexible adapter.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
where about in scotland are you mate? you close to Inverness?
iDemonix
Post by iDemonix »
xivlia wrote:where about in scotland are you mate? you close to Inverness?
RUN. TAKE THE BIKE. HIDE. GO!
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
:grin: :grin: :grin:
Seriously. do it. RRUUUUNNNNNNNN! :arrow:
xivlia
Post by xivlia »
...... im not that dangerous :(
mattchew13
Bike owned: RVF400
Post by mattchew13 »
xivlia wrote:...... im not that dangerous :(
Seriously... TAKE THE BIKE AND RUN. It's a lie!
