How much hight adjustment in an adjustable rear shock
NGneer
Post by NGneer »
I will be going to a 17" rear on my NC30 and of course convention says "you need the NC35 suspension linkages" to restore the ride hight at the rear end.
I am quite happy to get a set of these if I need them, but I already have a Nitron rear shock to use...
like this......
....and looking on the Nitron Website (http://www.nitron.co.uk/shop/product/14 ... hock-2-way) it does state that the 'Track Shock" has Independent adjustable ride height.
I am just curious if this 'adjustable ride hight' would be suffiecient to negate the need for the NC35 linkages when swithing to the 17" wheel.
Anyone tried this - or any thoughts (or anyone got an NC35 linkage lying around?)
NGneer
Re: How much hight adjustment in an adjustable rear shock
My ohlins has 15mm of adjustment. Personally I'd go for the rvf link aswell as I think the 30 squats as bit in stock trim so added height works well.
I might be taking a fully refrubed rvf link and dog bone off my 30 if your interested, never used just fitted up
steve92
Post by steve92 »
I'd be interested in that link if ngreer doesn't want it.
speedy231278
Post by speedy231278 »
Was that the linkage I was after but you couldn't find? ;-)
NGneer
Post by NGneer »
Drunkn Munky wrote:My ohlins has 15mm of adjustment. Personally I'd go for the rvf link aswell as I think the 30 squats as bit in stock trim so added height works well.
Cheers Tony. Deffo interested in the RVF linkage so give me a shout if it becomes available :peace:
speedy231278 wrote:Was that the linkage I was after but you couldn't find? ;-)
:oops: I never did find that one I must have sold it, this one is off my current build and is fully rebuilt and zinc plated, yours if you want it but I need to save up for the replacement linkage first
NGneer
Post by NGneer »
Image Speedy, look into my eyes, not around the eyes.....This is not the linkage you are looking for...let NGneer have it....3-2-1 and you back in the room :whistle:
speedy231278
You have it if you need it. Having a 35 means I already have one, I was just thinking about pre-empting the inevitable situation when I heave the old shock out and find the linkage has suspect seals or bearings by having a nice, fresh one to replace it with if necessary. Or just to do it anyway.... It's not like I need it to correct the geometry on mine.
NGneer
Post by NGneer »
speedy231278 wrote:You have it if you need it. Having a 35 means I already have one, I was just thinking about pre-empting the inevitable situation when I heave the old shock out and find the linkage has suspect seals or bearings by having a nice, fresh one to replace it with if necessary. Or just to do it anyway.... It's not like I need it to correct the geometry on mine.
porndoguk
Post by porndoguk »
This is me all over i like to refurb spares then replace directly, then sell the old on etc.
I do this especially in the summer to avoid any riding down time
