Super Corsa companion
Emzed
- Bike owned: NC23J/K,750Paso x2,MZ's,BMW C1
I have aquired a Super Corsa soft compound tyre for the front of my NC23 for trackday use
Can anyone suggest a suitable rear companion in 18" size ?
Or am I stuck with Bridgestone 090's ?
Em
Em
Emzed
Re: Super Corsa companion
Well I must say I thought I might have had at least one reply
Has anybody got "any" suggestions at all
Em
Em
Only advice I'd give is sell the supercorsa and fit a set of matching tyres, BT090's. Sorry
Drunkn Munky wrote:Only advice I'd give is sell the supercorsa and fit a set of matching tyres, BT090's. Sorry
This ^^
Or get a 17 inch rear to match.
I doubt that many people would want to try and comment on mismatched tyres due to the safety issues.
Matched tyres for the win!
silver1956
- Bike owned: Ducati 749S,BMW F800S,XBR500
I used 090's last year for trackdays and they were fine, not bad in the wet too. Not much choice if you keep the 18" wheel.
Dave
Dave
steve92
I used a bt090 rear and a supercorsa front on my nc 30 race bike with no problems at all.
Although i picked up a rvf wheel for £80 so i'll be on a supercorsa rear too this year.
Emzed
Thanks for the input peeps
This is all I wanted, just some thoughts based on your knowledge and experience
I'll probably try out the super corsa front with the 090 on the rear
And look to buy a 17" wheel for the rear
Although I suspect that will open up a whole new "can o worms" regarding fitting of the wheel and altering the rear suspension to take account of altered ride hieght
But at least I now have a "starting" point
Em
Em
Emzed
I have now aquired a 17" rear wheel from a Gull Arm
And a 17" Super Corsa 160/60 tyre
Are there any "issues" I should look out for when fitting it to the NC23
Like alignment, caliper spacing and ride hieght
Any help or suggestions from those whove done this already would be greatly appreciated
Em
Em
Emzed
The only "issue" I have found with the wheel swap is that the NC23 rear sprocket and cush drive dont appear to be the same
The cush drive from the NC23 doesn't fit as closely to the NC29 wheel as it's supplied carrier & sprocket (which I can only assume is original)
Also the NC29 sprocket is a 520 whereas the NC23 is 525
Whilst I can forsee no serious troubles, running a narrower sprocket on the rear, should I be looking to replace the gearbox sprocket and fitting a 520 chain
Any help or comments from those who have done the 17" conversion would be greatly appreciated
- Yakama
Emzed wrote:The only "issue" I have found with the wheel swap is that the NC23 rear sprocket and cush drive dont appear to be the same![]()
The cush drive from the NC23 doesn't fit as closely to the NC29 wheel as it's supplied carrier & sprocket (which I can only assume is original)![]()
Also the NC29 sprocket is a 520 whereas the NC23 is 525![]()
Whilst I can forsee no serious troubles, running a narrower sprocket on the rear, should I be looking to replace the gearbox sprocket and fitting a 520 chain![]()
Any help or comments from those who have done the 17" conversion would be greatly appreciated![]()
See here:
viewtopic.php?f=28&t=7679
