Headlight Issues!
Posted: Thu Dec 13, 2012 2:46 pm
Dear fellow bike gods,
I recently purchased a 1996 RVF400 fitted with a tyga kit. And I have been having issues with the headlights, I checked the globes and replaced them with new ones (the correct ones) and still am having problems. Before I replaced the globes the low lights would barely come on (very dim), and the high beams worked fine. After replacing the globes, only one of the low beam lights works correctly, and the other doesn't even light up. And Again the high beams work fine. Trying to isolate the problem I switched the wiring around on the globes and the other one lit up (which previously didnt light up), while the one that did light up did not.
Looking around the actual globe sockets it looks like some burning/charring has occurred. While reading up leads me to believe that my left gear switch may be blown/cooked from the over voltage. And I am going to order new headlight wiring from TYGA to be safe.
My questions are,
1. Is it worth going and replacing all the fuses to be safe?
2. Where does one obtain a new/working left gear switch (can't find one)
3. If neither of these issues fixes my headlight problem, what else could it be?
Any help is appreciated (thank you bike gods)
My questions are,
