Soft suspension nc21?
lukiooo
Post by lukiooo »
I was just wondering is the nc21 1986 designed with a soft suspension as I got the bike back from the garage and they said it was soft? There are no leaky seals that I can see. So was wondering if they are meant to be like that or be firm?
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: Soft suspension nc21?
Post by jim157 »
Most JDM bikes were set up soft from the factory to suit the lower weights of the average Japanese rider. Plus there's a good chance that your shock is probably 25 years old; and hence knackered.
A new shock would be your best bet.
AUTOEXEC.TWAT
lukiooo
Post by lukiooo »
Oh I see fair enough will look into it, do you know roughly how much they retail at?
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Anything from around £350 upwards.
lukiooo wrote:I was just wondering is the nc21 1986 designed with a soft suspension as I got the bike back from the garage and they said it was soft? There are no leaky seals that I can see. So was wondering if they are meant to be like that or be firm?
Front and back on the NC21/24 is extrememly soft.
This is typical of early - mid 80s hondas.
Providing it isnt leaking then it isnt worth upgrading, you will spend upwards of 350 quid on even a half decent rear shock and the front will cost at least as much, on a bike thats only worth around 500 quid to start with it isnt very economical.
Sounds normal. See my reply in this post
viewtopic.php?f=24&t=39670
You can get some aftermarket springs which will stiffen it up a little but that NC2x suspension is never going to set the world alight.
Dont let that put you off though, just becuase it isnt onpar with a 2012 motogp bike does not mean it isnt ok as it is.
