nc29 oil change question
Posted: Fri Nov 30, 2012 12:40 pm
Got a couple of questions for you good folk, first of all, when I do my oil change is it essential that I change the magnetic washer that sits on the sump plug? I did order one recently but cleverly decided to put it in a safe place, which I now can't find, so was wondering if I can do this without changing the washer?
Also, with regard to the dip stick. when I take it out, it has 2 markers on it near the bottom, and a number 4 stamped between the 2 markers, I presume (and I know historically I should never presume anything) that the oil should be topped up to the upper marker. Is this correct?
Thanks once again in advance
Michael.
Michael.
