Brake Lines EN2 Frame, TCAT front end, R1 Calies, 3TJ Master
Posted: Tue Sep 30, 2008 8:17 pm
				Help, I don't know much about brake lines, I just thought they were a certain length with little silver hoops at each end!
I've got a TCAT front end on my EN2, with R1 99' Calipers and a 3TJ master cylinder mounted on risers and a custom straight handle bar.
I've tried borrowing some new 99' R1 front lines front work on the basis that I could offer them up and just order longer ones. Unfortunately, there seems to be very very little play in the angle of the banjo bolts.
I know I need some lines about 5" longer each side than the R1 lines, but I've know idea how to measure or specify, - or even find out the right angle of the banjo bolts at either end. - All I know is that they don't twist to a position that's easy to mount at both ends (typically just the caliper end lines up).
I can force twist one end to fit the master cylinder with a pair of pliers, but I figure this can't be good on the lines. Any advice on ordering, speccing up custom lines would be appreciated? - otherwise, I may just get an R1 master cylinder and order longer R1 lines. - But i'd rather not spend more than I need to.
