RVF400 low beam not on
Posted: Wed Nov 28, 2012 11:03 am
Hi all,
I've searched through several threads and forums and decided to post as I'm not quite sure what i can do.
Issue : My missus' rvf400 was working fine but one morning, the bike won't start. We changed the battery(I had a few spares) and it was all working great until one day the low beam(bulbs are ok though, filaments intact) stopped working(high beam works). It has the standard 35w bulbs fitted and not the h4's so not likely a reason to fry the lhs light switch. However, after riding for a few days, the battery will be drained completely where the bike won't start if stalled.
I have 3 batteries all holding 12.8v off the bike and with the bike running at idle as follows
idle with low beam(no lights though) : 12.8V
idle with high beam(lights on) : 12.4-12.6V
Rev at 5k with high beam : 13.5-14.
From the info above, I can only assume that the high beam(since low beam not working) is drawing too much current, and since my missus' commute is on the short side(6miles in heavy traffic), it drains the battery to a point if she stalls, it wont't start. Does it look like the regulator is on the way out etc?
Is the above true? Or should there be no impact when running at high or low beam?
2nd of all, since the bulbs are fine, I can only presume its the light switch. Can i take the switch gear off the bike-(discconenct from loom) and take it apart in the comfort of the house? From a quick check yesterday, it seems that the lhs loom connects to the main loom and unable to disconnect. Please correct if wrong.
Last of all, what do i need to do with the switch gear to get it working again?
