Battery
tonfanau
- Bike owned: suzuki 884 bandit, NC30 Z750
Battery
Talking of batteries ive just fitted an alloy subframe for my Nc30 race bike,
The subframe is for the NC but the battery tray is smaller, narrower than normal, i could cut it and mod it except the proper NC battery but i wondered if you guys could recomend another battery with the same wattage, ampage to cope, the tray size is 115mm long, 85mm wide and 125mm depth, Alister
johnnie5
Re: Battery
i cant tell you which but you can work it out for yourself
stock is YTX7A-BS
go here
http://www.road-star.biz/battery_en.html
lists all battery specs , so should be able to work out what will suit your needs
other options would be a shorai/ lipo etc new age batteries which are smaller , more powerful, lighter
there is a few brands around so worth a look just on the weight savings alone
stock is YTX7A-BS
go here
- thunderace
- Bike owned: R6, YZF600R
Re: Battery
I can make you a LiPo race battery when I'm back off hols if you're interested
tonfanau
Re: Battery
Hi
Yes i would be interested in having a race battery made, ive put the measurements of the battery tray on my original posting, how much would it be to make one, how long would the charge last for, as im running total loss,
thanks Alister
thanks Alister
